Vfr400 battery strap
Romney1
Post by Romney1 »
Hi my battery strap is missing could anyone provide measurement of theres or provide a part number cant seem to locate a replacement . Also on the honda site the battery strap number is for the tool kit one so dont fancy ordering the incorrect one
NGneer
Re: Vfr400 battery strap
Post by NGneer »
Have a look here https://www.cmsnl.com/honda-vfr400r3-19 ... ml#results
Both straps are listed but I would suggest they have got the descriptions the wrong way around - IE item 12 is actually the Battery strap and not the one for the Tool box as listed (and vice versa). Your problem is you don't know if it is just the description that is the wrong way around or the item numbers as well. :?
Could be worth an e-mail to CMSNL
Romney1
Post by Romney1 »
Can anyone provide the length of theres ?
Foxy400
Regular Member
Bike owned: NC35 NC29 Bonneville Daytona
Post by Foxy400 »
I'm pretty sure it's the description that's misleading and part 12 is the battery strap (as shown in the diagram). If you google the part no. it comes up with the same description for this part on a variety of Hondas. In other words, Honda Japan have written the description not cmsnl, so unless the cmsnl people actually dig out the parts and check them on the bike (assuming they have an NC30 to hand) they're unlikely to know. But I guess it's worth an email.
If I owned an NC30 I'd have a look for you Romney1 but I don't.
NGneer
Post by NGneer »
I will have a look for you this afternoon when I get home :peace:
NGneer
Post by NGneer »
Tool box strap above, Battery strap shown below.
Hope that helps
Romney1
Post by Romney1 »
Thank you very much i have managed to locate the correct length on line made up .
Kyle3076
Post by Kyle3076 »
Where did you source from
newtothis
Bike owned: YZF R125, RVF400, Morini 3 1/2
Post by newtothis »
I searched for a 120mm battery strap and found a Yamaha one part no 7H3-82131-00 from salvagehunter15 on ebay, though it looks as though they've all gone now. If their part numbering is anything like honda the same part may have been used on other models with a minor code change
The number on the strap itself is 7H3-00
Romney1
Post by Romney1 »
Got it off the bay . Only about a £5 was a universal strap im sure it was 110 mm fits perfectly i cant find the item listed atm but i just kept searching
