Ohlins shock
saltysealion
Ohlins shock
Hi,
I'm looking to replace my OEM shock with an ohlins shock. Is someone able to recommend a model that would suit the RVF without or with very little modifications?
lukemillar
Re: Ohlins shock
CBR900RR Ohlins shock is what you want but you would might need to modify the length
Re: Ohlins shock
RC30 ohlins slots right in
magg
- Bike owned: VFR400
Re: Ohlins shock
Mecadata.com or ebay mecadata-france claim to have Ohlins to fit an NC30. Worth considering if it comes valved and sprung to suit.
- Tim400GB
Re: Ohlins shock
Kais supplied mine, modified/valved etc and ready to fit.
Re: Ohlins shock
indeed.Drunkn Munky wrote:RC30 ohlins slots right in
i had an rc30 shock that was adjusted to suit the nc30, worked rather well too, far better than i could have asked of it.
violetpop
Re: Ohlins shock
Got a nice wilbers unit in mine, nc35 specific
Sent from my SM-G935F using Tapatalk
- RickOliver
Re: Ohlins shock
The stock RC30 shock is actually shorter than the NC30 one. As stated above, the shock that you need is a modified Fireblade unit - KAIS have the spec and will build it for you.
(I don`t know if Timon has the same experience but on my Ohlins they have craftily ground off the original part number from the shock body so you can`t tell which `blade shock it`s based on...)
- Tim400GB
Re: Ohlins shock
Never noticed that, where would it have been? I'll take a look
richyrd5
Re: Ohlins shock
Just outa intrest,what year blade shock fits and do any of the later(rr4+)standard shocks fit??
