nc23 ram air
nc23 ram air
does anyone make ram air for the nc23? i have seen a few modded airboxes but nothing designed properly, or am i gonna have to make my own
Re: nc23 ram air
there is a guy on here going under the name chrisxr750 i think who has made a full ram airbox
seach his name in the members section and send a pm
stimpy
stimpy
- leopard_pagan
- Bike owned: used to have a NC29
Re: nc23 ram air
i dont think there are "off the shelf" ram air for bikes this old.. most i have seen are DIY jobs..
Re: nc23 ram air
cheers guys, well i have all winter to design one so i think i may have a go to see how it works, at the moment i am living in brno and its dirt cheep to get on the race track here and test it back to back with a standard setup, also lp i think i remember you did some resistors for led indicators in the past or am i mixing you up with someone else? if so i may need some for my road bike
- leopard_pagan
Re: nc23 ram air
aye i play with LEDs.. am mid-project with Banshee with a custom rear lights, when he decides to order up the parts + have the speedo restrictor de-limiter kit or DIY instructions for NC23 1998<
used to build "idiot lights" for track use.. youd get Red= oil and Green = neutral lights all 12v ready + long enough cable for fitting.
Re: nc23 ram air
what im after is the resistors to allow led indicators to work, im pretty useless with electronics but am starting to learn more as my cbr is a track only bike and im getting fed up with masses of spare wiring so may be doing a loom job over the winter
Re: nc23 ram air
ian...chris's ram air has been design and tested on his dyno and it works...
it bolts upto the 23's orig airbox base mount...
get hold of the guy
stimpy
get hold of the guy
stimpy
- leopard_pagan
Re: nc23 ram air
if its a track bike... no need for indicators.. unless its on a day time MOT so you can get to track?
options to get LED indis working are:
1st thing to do is change the indicator flasher unit for a LED one.. google em up, motrax do them for Honda with a honda plug.
depending on how your indicators are acting after the flasher unit, flashing at right rate but as hazard lights? then you also need option 2 VVVV
2nd option are Load resistors... you can buy them from ebay. i have a pair on my bike + LED flasher relay.
basically if you buy LED pre-built indicators, its NOT a good idea to start messing about with them, mainly due to the fact that we dont know what spec the LEDs are to be able to get the right resistors. the wrong Res = leds can blow up from too much voltage or not work at all = not enough voltage.
Re: nc23 ram air
they are for my yzf750 road bike, my race bike is stripped to the bone
