Nc 35 headlight problem
				LennonRVF400
My head lights stop working on the rvf could be gone for a day or a few days and  then they could work for a few weeks. The horn also goes at the same time any1 know what this could be cheers.
Re: Nc 35 headlight problem
The headlights and horn share a earth feed so my guessing is your've a loose/broken wire up behind the clocks somewhere
				LennonRVF400
I will have a look cheers
				magg
 - Bike owned: VFR400
Whole bike shares common earth in the loom, any other electrical functions go missing?    So could be loom fault or horn fault is co-incident and headlight fuse intermittent or intermittent engine start button.    Do you have headlights on with ignition switch on?    Place bike on side-stand, ignition switch on and wiggle engine start button, do headlights go on and off?
What i meant by sharing an earth feed is that the headlights and horn will be on the same branch of the earth feed so the break will be before the feed splits off to horn and lights
						- speedy231278
I've give even money on the connector under the tank for the switchgear being corroded.  Most of the gremlins I've had that haven't been the charging system have been one of these getting crap in them.
				LennonRVF400
Just wingled the start switch an the lights came in what does this mean
				magg
Sounds like the "headlight off while engine is cranking" switch contacts located in the start switch are the issue.   Might be fixed by simple dis-assembly and a clean, watch out for small springs escaping, or even just a spray of your favorite contact leaner, but dis-assembly would be my preferred option.
				LennonRVF400
Thanks  I'll  have a go at it 2morrow  will let ye kno how I get on
				LennonRVF400
Took the switch appart  it was covered in dirt on the inside cleaned it all an put it back together..seems to be working as it should thanks for the help
