GK73A front sprocket
				bluex5
I've been preparing my gk73 frame to go for welding on the broken engine mount, the guy wants the engine so he can check his  work after doing the repair, so i've been refitting the sprocket cover so i don't lose the clutch pushrod etc. I've noticed the front sprocket is quite sloppy on the shaft. I'm not sure how much slop is too much, i appreciate it's a floating design with just a circlip. The splines on the shaft don't look too hammered, is it worth changing the front sprocket for a new one and hoping this takes up some of the slop?
						- Variablevalves suck
Re: GK73A front sprocket
A new sprocket should help a bit but they are a pretty loose fit.
				bluex5
CheersVariablevalves suck wrote:A new sprocket should help a bit but they are a pretty loose fit.
 i somehow thought that might be the case, bit heath robinson but if thats how they are...
