Carb cleaning
Carb cleaning
Right. No matter how many times I clean them out its not good enough. Bike had been sat since 1999. Where is the best place to get the carbs cleaned properly?
- micpec
Re: Carb cleaning
Where are you located? That may help to advise you into the best direction. I am confident that members on here will show you there. Or buy yourself a ultrasonic cleaner+liquids for DIY with manual.
Re: Carb cleaning
Not a bad idea at looking into a cleaner. Would use it a lot. I am in west sussex. Uk :)
Re: Carb cleaning
some heavy duyu carb cleaner but you must blow the passages out with high pressure compressed air to clear the stuff out.
Re: Carb cleaning
Doesn't even touch it. The varnish is like rock
Re: Carb cleaning
Have an ultrasonic cleaner on the way woop
Re: Carb cleaning
prooper heavy duty carb cleaner will work, but proper stuff (i.e. professional cleaner) but it will eat the rubber diaphrams and seals almost instantly so you have to fully strip the cabrs to use it, also contains a lot of MEK and other natsty stuff.balashark wrote:Doesn't even touch it. The varnish is like rock
Probaby hard to get anyway so ultrasonic cleaning is probably the easiest way.
- Bike owned: NC35, 5SL, 3XV, 2MA
Re: Carb cleaning
In your ultrasonic cleaner, use the following recipe:
Hot Water - 4 cups
Fairy Liquid - 1 tablespoon
Vineger - 1 cup
Salt - 1 tablespoon
Cook for as long as necessary, and a VERY good rinse out afterwards. Better than ANY commercial cleaner I've tried...
Probably a good idea you accept all your jets, etc. are shagged so remove the lot before cooking.
Hot Water - 4 cups
Vineger - 1 cup
Salt - 1 tablespoon
Re: Carb cleaning
Thank you :)
- One Hit Wonder
- Bike owned: VFR400 NC24
Re: Carb cleaning
Take lemon juice, put carbs and juice in a container and let it boil.
Lemon juice eats all the grime. But dont do it for too long.
