Which carbs do i have?
willpisme
- Bike owned: NC30, R1, CB250RS, FZR400
Getting some new airbox rubbers as mine are solid. Just wondering what model carbs i have. There is no return cable on the carbs and no place for one.
The reason i ask is the bike is a bit of a mix of models and i hear the rubbers can be different??
willandrip
Re: Which carbs do i have?
SP 2TK carbs have metal tops as yours appear to have and no return cable.
The earlier Genesis has the return cable.
The later 3EN2 has plastic tops.
I have no input on 3EN1 carbs.
These are 2TK;
The Genesis airbox rubbers fit and are readily available at reasonable cost.
These are 2TK;
willpisme
thanks thats exactly what i needed to know!
They look identical to yours.
Any recommendations on where to purchase the rubbers?
willandrip
http://www.cmsnl.com/yamaha-fzr400u-198 ... wg1445300/
See... told you they were cheap......... postage may push up price though.
This is also a know work around for hardened 3TJ rubbers as confirmed by Southend Chris.
willpisme
spot on, much cheaper than expected! Cheers.
Might aswell carry on the the Q&A now the camera's out ha ha.
Any ideas what this wire is for, the connector with a blue wire and black? wire. Its sat loose for all of last season and had no ill effects, just curious as to what it could be.
willpisme
i've just realised what its for. The fan.... Which has never been fitted!!
suzkistorey
- Bike owned: FZR400
I was going to say it was for the fan, I found it was the longest wiring on mine and poorly wired up, get yourself some 2 pin way seals to wire up, quicker if you ever need to disconnect.
http://www.ebay.co.uk/itm/261392575802? ... EBIDX%3AIT
willpisme
thanks for the link have ordered some as theyre always gonna come in handy.
The main problem i have is that the fan isnt even on the bike, its actually "blown me away" that ive ridden track days all last year without bloody noticing it doesnt have one ha ha. I guess for me anyway i just assumed it was there even when changing the plugs etc i didnt notice it!
You can probably find one, it shouldn't be to much.
it's not so bad when the bike's moving it's when you ride in traffic.
Taggyd
I've got a fan off a 3tj dunno if they the same?
