r1 front end one fzr400 1wg
Re: r1 front end one fzr400 1wg
willandrip wrote:May I humbly point to this;
viewtopic.php?f=37&t=43067
il read that now
cheers ollie
The engine fitting work was done prior to purchase;
The pics in the post pretty much show what is required better than a description.
Briefly;
Rear engine mounts altered.
Front engine mounts/hangers fabricated and welded in situ.
Rear arm and wheel from FZR1000r fitted to line up and utilise 17" rear wheel.
R/h footrest assy packed off frame with spacers to clear s/a travel
L/h footrest brackets cut from frame and relocated outboard to clear s/a and chain.
Cutouts/patches to inner frame rails for carb fitment.
The major loss on the 3EN2 would be the frame rails to locate the fairing fixings on.
This could be overcome by refab work and brackets which I did originally intend.
Access to an ally welder would be needed to repeat this exercise economically.
If you have no access to mig/tig gear and the skills to go with them then this would be very hard to keep in budget.
It is for this reason why the pre 3TJ frames are best suited to the FZR600 3HE engine swap; it is all bolt in stuff.
Briefly;
luckily the isle of wight has a large amout of boat builders etc so finding someone to do the welding wouldnt be to much hassle im just wondering if it would all be worth the effort and cost from the extra hp over the T-cat swap?willandrip wrote:Access to an ally welder would be needed to repeat this exercise economically.
cheers ollie
By access; I meant you need to be able to do it yourself.
Welder/fabricators are not the cheapest.
T/catwould be less work but will still require front frame hangers I believe.
3TJ is best suited to 600 Foxeye and ThunderCatwillandrip wrote: If you have no access to mig/tig gear and the skills to go with them then this would be very hard to keep in budget.
1WG is suited to 600 3HE.
Its down to the earlier engines mounting on the front of the gearbox
The later bikes mount to the side of the engine head so the engine is a stressed member.
so all in all a Fzr600 3HE engine will be the most strait forward swap with the least major (frame) mods?Evilchicken0 wrote:3TJ is best suited to 600 Foxeye and ThunderCatwillandrip wrote: If you have no access to mig/tig gear and the skills to go with them then this would be very hard to keep in budget.
again cheers for all this advice guys your a great help this is all much appreciated
Ollie
What front callipers are they ?IOWfzr wrote:willandrip wrote:Get a YZF 750 shoehorned in !
that was my original idea but i had been told/read it wasnt do-able.....but if it is thats what il do![]()
im up for a challange
cheers Ollie
They were FZR 1000r / RU but I replaced them with blue spots later when a cheap set came up.kawasakiinit wrote:
Before you ask Dave; the 2TK legs, even though being 38mm had 100mm spacing for the calipers as did the next model, the 3EN1.
You could upgrade with those legs cheap enough if you got the discs; if that was what you were thinking.
Bill are u a mind reader lol. Just in the thought stages yet ,do the blue spots bolt straight on ?
Bolt straight up onto ;
SP 2TK
3EN1
600 3HE (but not the 89 model; it has the same caliper as your Genesis.)
The Genesis has non offset discs of a different diameter.(need swapping)
It is highly recommended to swap out the master cylinder with a one matching the calipers.
This is non radial calipers mind ; not the square shaped later radials.
SP 2TK
3EN1
