hard starting....
wullvfr
Bike owned: zx9r c1
Re: hard starting....
Post by wullvfr »
the rear two spark plugs are easy to get at but the front two are a pain.....you will need to loosen off the upper radiator lower bracket and push it 4ward.
if yo do not have the spark plug spanner then it is a deep 13mm socket you will need if i remember correctly.
and whatever is needed to screw the tester in!!!!!
william
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
wullvfr wrote:the rear two spark plugs are easy to get at but the front two are a pain........you will need to loosen off the upper radiator lower bracket and push it 4ward.
:shock: :?:
'Take it to the Back'
leopard_pagan
Post by leopard_pagan »
go in via radiator?
hell no.. it takes me 15mins to get to plugs via air box/coils... changed plugs several times so its easy for me to do.
i just need to collect the relevant tools together to bring to work to do in lunch time.
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
both ways are about the same hassle.......
either way gets the job done!!!!!
william
leopard_pagan
aye... lol.. i did go in via the radiator once... i had twinges in my back for days afterwards! thats why i prefer the tank etc way.. no odd positions
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
lol!!!
thats maybe where i get my sore backs from haha.....
noticed today number two is not firing....or so i believe,exhaust was stone cold so it looks like its out with the plug and see if it is sparking.
happy days!!!!
im lucky though,my bike is off the road so i aint in a rush and can take my time.
william
leopard_pagan
This morning my end can sheared off the headers after hitting a bump, i suspect its been slowly tearing the weld for a while.. and i think it was caused by the MOT guy putting a rolling jack under the headers to lift the front up to check head race bearings 3 weeks ago...
also 3 weeks ago my bike started having starting issues.
i am wondering If the end can working its way off has caused the hard starting issue?
i am still doing a compression check some time this weekend.
