Quick action throttle
Stretch85
Does anyone know if their is a throttle tube off another bike that will give me a faster action ? I have tried the plastic pipe mod but nothing will stick to the standard tube
willandrip
Re: Quick action throttle
SP2TK has a q/a tube (1/4 turn) but has only the opening cable.
Have you tried pvc pipe solvent adhesive ( it melts parts together.)
I reckon the adhesive in the Q-Bond kits will glue virtually any plastic.
On a scale of 1:10 , I rate it 20.
Stretch85
2tk sounds like the way to go I have true the plebes solvent and it didn't work
Stretch85
That should have read plumbers solvent lol, does anyone have a part no for the 2tk throttle tube ?
willandrip
Yes I gathered that !
Only a handful of people in the UK have a parts manual.
Doubt they are still available new but try a good Yamaha dealer with;
1KG-26240-00
What happened with the misfire malarkey ?
Have you considered a complete q/a assy and a separate start button ?
Addition;
Unbelievable;
http://www.ebay.co.uk/itm/YAMAHA-FZR-40 ... 1#shpCntId
1KG-26240-00
Addition;
Unbelievable;
Stretch85
Changed could plugs and leads before I went testing so problem solved on the misfire front, , I'm a little short on room on the bars so its a bit tight for a motorcross job
Stretch85
*coils
willandrip
IMPORTANT ADDITION;
I went into the garage today to see just exactly how much less rotation was required using a 2TK throttle
tube versus a 3EN or Genesis twistgrip.
It turns out (pun intended) that the tube has the same rotation.
It is the throttle quadrant on both the 2TK and YZF750 carbs that reduce the degree of turn required NOT the tube.
Taggyd
I used a universal venhill one on my track bike. Should fit yours if you want a true q/a throttle.
