nc30 carb jetting issue..
Re: nc30 carb jetting issue..
Neosophist wrote:
Drunkn Munky wrote:Defo bukudan jet and needle kit then as mentioned above, I spent all weekend trying to get the bike running sweet with that kit but gave up in the end.
what parts did you have your with kit? Ive seen a few listed forsale without everything and that aparantly makes them even harder to get running...
Jets and needles
TommyTheGun
Post by TommyTheGun »
Spenceley, i have a set of standard emulsion tubes for sale if you want. Pm'd you.
spenceley1
Bike owned: CBF500-NC30
Post by spenceley1 »
So I rebuilt the carbs, put the jets in the right way, 115 front, 117 rear, adjusted pilot screws and stuck it all back together, now when I start her up and just let her run its absolutely fine, revs freely, idles well and everything but went to go for a ride today and as soon as I go to pull away it just heavily bogs and dies, I can just about get her to go using a lot of clutch and once I let the clutch out, will chug along for about 5 seconds at like 2k revs then die, once the clutch is out like that no matter how much throttle I give she doesn't react at all...
Am seriously stuck as to the problem, please help :)
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
Sounds like you are flooding it with too much fuel. Do you still have the bukudan parts in the carbs? I would get rid of them and go back to standard. Also, is the airbox stock? A lot of people try to improve on the intake and usually ruin the fuel metering in the process.
spenceley1
Would it flood it just by letting the clutch out and revving a little? Yeah still got bukudan parts in at moment, working on getting standard, but it did run pretty well with them before I sat it up for a good few months.. Airbox is standard too...
Whats the chance of it being a clutch issue? A friend was over and said he thought that could be the issue if it's seized itself up a bit or anything?
stevie
Bike owned: 92 uk model nc30
Post by stevie »
It may be u have an air leak, just check to make sure the carbs are seated properly, & that all of your clamps & hoses are done up nice & tight & fitted properly. It sounds more like an air leak than a fuelling problem especially as it was running ok before hand. Hope this is of some help, good luck, Stevie.
spenceley1
Yeah cheers mate, will check it all again when I get a chance, in the process of moving house and job at the same time so everything is a little bit manic at the moment!
Will update once I get a chance to look at her, have got standard jets now so might put them in too and see if it helps :)
