Rev counter still not working.
wambam87
Re: Rev counter still not working.
Post by wambam87 »
After some help from my dad, I have 13v ish at my tachometer, and 0.5 volts from the signle wire. Are these values enough? Or is my new tacho dead too?
Cammo
Post by Cammo »
Are you sure you have the correct tacho for the bike? Rvf and vfr are not interchangeable.
On the rvf tacho 0 rpm is in the 6 o'clock position, on VFR tacho it's around the 4 o'clock position.
magg
Bike owned: VFR400
Post by magg »
12 volts
Post by Neosophist »
Cammo wrote:Are you sure you have the correct tacho for the bike? Rvf and vfr are not interchangeable.
This is important.
You cant use the wrong tacho :)
wambam87
Post by wambam87 »
Have checked and there exactly the same. There's a "working" tachometer on ebay at the moment, going to see if I can nab it.
Cammo
Post by Cammo »
Do you have the earth wire screwed onto the back of the tacho?
