NC29 Carbs
NC29 Carbs
Hi all
Question about carb ugrade:
So after some reading Keihin 32mm FCRs are the upgrade most used as they fit the standard boot size but I have also read about people using Keihin 32mm CR Specials. As it seems quite hard to get hold of FCRs (none on eBay
) there is a set of CRs (on eBay near to me). From what I've read (again) the CRs require a bit of work to make them fit?
Does anyone know what has to be done to the CRs to make them work or if they are a good/viable option instead of the FCRs?
Also if anyone had any ideas of cost etc or where best to shop for these that would be great.
Just one more question - which Mikuni carbs are the equivalent of the Keihin FCR as I've just be told that Mikuni are about 1/2 the price with little noticeable difference...
KC
KC
Re: NC29 Carbs
Why do you want to upgrade?
I think you need special rubbers to mount the fcr's too.
Re: NC29 Carbs
Hi
It's a project bike...and one I'm going to keep so just looking at everything and anything I can upgrade (within money cost limits!). I'm under the impression that Keihin or Mikuni provide more power and that they're a nice bit of bling as opposed to say Dynojets?
Thoughts? Also where would you get the mods needed to fit these carbs - you say special rubbers?
Ta
KC
Ta
KC
- lloydspencer
- Bike owned: NC29, RS250, Goose, RGV250 VJ2
Re: NC29 Carbs
Some people have said that a small amount of modification has to be made to the frame for these to fit.
I owned a set but have never used them as I sold before attempting.
You can still buy the FCR carbs brand new but will cost you a considerable amount of money.
You will also need a set of Carb Rubbers for them to fit which a very very rare. The ones that are still circulating can be in slightly poor condition before of their age.
I have found the Australian Ebay is a lot better for CBR 400 performance parts.
When your Aprilia RS250 is more reliable then your girlfriend then you know it's time for her to go.
Re: NC29 Carbs
Bugger all on eBay over here
Stimpy
Stimpy
