Clutch Issue.
- Sam-NI
- Bike owned: '89 VFR400
Clutch Issue.
I think I might have a problem with my clutch.
I don't think its disengaging the plates completely when I pull the lever.
Here are the symptoms.
With the engine off, if i'm in neutral, I can roll the bike with very little resistance. If I put it in first, and hold the clutch lever in to the bar, there is slightly more resistance. It's not alot, but it's noticeable.
Is this normal, or is there something wrong?
Me? The 13th Duke of Wymbourne, Here? In a French maids finishing school? At 3 O'clock in the morning? With my reputation?
BINGEAU!
BINGEAU!
- mo haggs
- Bike owned: bikeless
Re: Clutch Issue.
Nothing strange there bud, most all 30/35's do it.
You could tighten up the clutch cable but you risk causing it to slip under load.
Re: Clutch Issue.
perfectly normal.
- missis sumner
- Bike owned: NC30 + Teapot
Re: Clutch Issue.
How old is your oil?
- Sam-NI
Re: Clutch Issue.
Glad its normal. Oil is fresh, only 150Km on it. Mo, you wouldn't happen to have the wee part i'm looking for in the wanted section would you? I've tried most of the NI boys already!
BINGEAU!
BINGEAU!
- Bike owned: MG v35 II, NC30, MG NF Mil.
Re: Clutch Issue.
If it bothers you you can fit these http://www.ebay.com/itm/Honda-CBR250-CB ... 22&vxp=mtr
The lever allows for more travel.
- mo haggs
Re: Clutch Issue.
Sorry mate, i run 35's - only the 30's have the tourqe arms.Sam-NI wrote:Glad its normal. Oil is fresh, only 150Km on it. Mo, you wouldn't happen to have the wee part i'm looking for in the wanted section would you? I've tried most of the NI boys already!
I may have A bolt that would fit but deff not have the spacers.
What length is the bolt? And i'm guessing it's the usual M10x1.25 thread pitch.
- mo haggs
Re: Clutch Issue.
Could you not make some spacers up?
