Clutch Issue.
Sam-NI
Bike owned: '89 VFR400
Clutch Issue.
Post by Sam-NI »
I think I might have a problem with my clutch.
I don't think its disengaging the plates completely when I pull the lever.
Here are the symptoms.
With the engine off, if i'm in neutral, I can roll the bike with very little resistance. If I put it in first, and hold the clutch lever in to the bar, there is slightly more resistance. It's not alot, but it's noticeable.
Is this normal, or is there something wrong?
Me? The 13th Duke of Wymbourne, Here? In a French maids finishing school? At 3 O'clock in the morning? With my reputation?
BINGEAU!
mo haggs
Bike owned: bikeless
Re: Clutch Issue.
Post by mo haggs »
Nothing strange there bud, most all 30/35's do it.
You could tighten up the clutch cable but you risk causing it to slip under load.
Re: Clutch Issue.
perfectly normal.
missis sumner
Bike owned: NC30 + Teapot
Re: Clutch Issue.
Post by missis sumner »
How old is your oil?
Sam-NI
Re: Clutch Issue.
Post by Sam-NI »
Glad its normal. Oil is fresh, only 150Km on it. Mo, you wouldn't happen to have the wee part i'm looking for in the wanted section would you? I've tried most of the NI boys already!
BINGEAU!
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Re: Clutch Issue.
Post by krisztian_andre »
If it bothers you you can fit these http://www.ebay.com/itm/Honda-CBR250-CB ... 22&vxp=mtr
The lever allows for more travel.
mo haggs
Re: Clutch Issue.
Post by mo haggs »
Sam-NI wrote:Glad its normal. Oil is fresh, only 150Km on it. Mo, you wouldn't happen to have the wee part i'm looking for in the wanted section would you? I've tried most of the NI boys already!
Sorry mate, i run 35's - only the 30's have the tourqe arms.
I may have A bolt that would fit but deff not have the spacers.
What length is the bolt? And i'm guessing it's the usual M10x1.25 thread pitch.
mo haggs
Re: Clutch Issue.
Post by mo haggs »
Could you not make some spacers up?
