GK76A Gaskets
Gash
GK76A Gaskets
Hello,
Does anyone here ever use aftermarket gaskets for their rebuilds? If so, what are they like, good or bad, or not worth the risk? Have had a look at the Suzuki valve seals and they are £5.97 each, that is nearly one-hundred quid for sixteen valve seals; bloody ridiculous! Is this what everyone pays for them or is there a cheaper alternative anywhere?
Cheers.
Cheers.
- Variablevalves suck
Re: GK76A Gaskets
I always use the OE seals as the cheaper ones have a tendency to leak.
Its your call mate.
Its your call mate.
Gash
Re: GK76A Gaskets
Cheers for the quick reply and I knew you were going to say that, as I knew it myself deep down. But bloody hell, Suzuki know it as well. I priced these valve seals up about four months back and they were £4.50 each, now they are £5.97. What has happened in that time for them to go up nearly £1.50 each?
Marsbar
Re: GK76A Gaskets
Yh the seals are fkin expensive, :/ so are most the gaskets for the bike, cost me a bomb to get the head gasket,
Also, If you contact redcar suzuki through gsxrjunkies you get 10% of your order
thats were i got mine from, think it came to £96
Gash
Re: GK76A Gaskets
I have looked at the price of a OEM head gasket and it is priced at:
Head Gasket 11141-32C10 £30.61
Marsbar, who is 'gsxrjunkies' ?
Re: GK76A Gaskets
Some of the gsxr 750's use 4mm seals, also zx6 and cbr6.
If you can find the sizes for these you may find a cheaper seal.
Marsbar
Re: GK76A Gaskets
Variablevalves suck wrote:Some of the gsxr 750's use 4mm seals, also zx6 and cbr6.
ive got a handful of zzr600 seals in front of me as i just done full engine rebuild on the motor, 1993 model, there same as the zx6.
Re: GK76A Gaskets
You find the seals are used across different makes/models as they standard sizes, say 4x7.5x10mm etc.
Marsbar
Re: GK76A Gaskets
i dont really know were to measure with these things, 9.40mm OD 9mm height. bare in mint i am not very good with a micrometer and it is rubber :/
jonhunt85
- Bike owned: top of my head 14 so far
Re: GK76A Gaskets
i after a Clutch cover gas kit for a GK76, any idea on price and place to get one before i try my local.
manny thanks Jon
manny thanks Jon
