Will any year engine fit my 89 nc30?
laurence_13
Post by laurence_13 »
Need to get a new engine for my nc30 so just wondering is there any difference in mountings, electronics etc between the years? can i get any engine and bolt in or does it need to be an 89 one?
bikemonkey
Re: Will any year engine fit my 89 nc30?
Post by bikemonkey »
No difference I don't think, should be fine as long as it's an NC30 engine :peace:
laurence_13
Nice one, thankyou!
You technically fit an NC21, 24 or 35 too - but they take more than plug and play.
Any NC30 motor will fit straight into your bike.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
So long as its a jap import one and not a UK spec motor or you will need more bits to fit it (which you will struggle to buy)
VFRkieran
Bike owned: NC30, NSR250, CBR600, TS125
Post by VFRkieran »
Whats wrong with your old one?
laurence_13
CRM wrote:So long as its a jap import one and not a UK spec motor or you will need more bits to fit it (which you will struggle to buy)
I think it's jap... will the logbook tell me?
VFRkieran wrote:Whats wrong with your old one?
was hoping no one would as that :lol: for some reason, i can only think i didn't select the gear properly, it jumped down from 5th to 4th when i was about halfway through the gear which obviously wound the engine right up, I can only think that the valve springs on the back right hand cylinder must've been weaker than the others as the valves on that cylinder hit the piston, completely mashed the piston head and barrel... i would repair the engine but because the barrels scored the parts are only slightly cheaper than a new (used) engine, so going to either keep it for spares or split it right down and sell the good parts on... bit annoying though!
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
It's an 89 bike, they only came in Japanese ;)
laurence_13
thanks. :) thats ok then
UK bikes have an oil cooler, so obvious if yours has one already...
