Nc30 fork settings
- V4beermonster
- Bike owned: Vfr400,gt750,vfr400/750cc
Nc30 fork settings
Anyone got the. Standard fork setting for late type forks? Just fitted RO fork kit want to start somewhere near standard
Re: Nc30 fork settings
It will depend a lot on your weight and where your riding if you want it super tuned.tlnut wrote:Anyone got the. Standard fork setting for late type forks? Just fitted RO fork kit want to start somewhere near standard
Between 25 - 30mm of front sag is a good setting to aim for. Set it with the bike on a level surface and adjust the brass screw so it is all the way out (off) while setting the sag.
Every increase / decrease of the rings on the NC30 preload adjusters will alter the sag by 3mm I seem to remember.
After getting the sag adjust the brass screw adjuster fully in and then out 4 clicks as a good start.
Don't forget to check your rear suspension after changing the front as it might need some adjustment.
- V4beermonster
Thank you gives me a starting point
Delboy
Failing that, these guys will set it up cock on http://www.revsracing.co.uk/aboutus.php
