Can you see what it is yet
Re: Can you see what it is yet
Post by Evilchicken0 »
Not many pics of this bit.
I ordered a box of bits ... they arived and I've cleaned up the brakes front and rear. new pads in and bled.
One thing I remember from my last 3TJ - why do they put that stupid thing on the master cylinder reservior ??? the clip with the nut and bolt that seizes solid .... I cut it off.
Found out the back disc is warped but then when I came to undoing the disc bolts one rounded out, still it's a good excuse to use the angle grinder. A few minutes with the grinder and a bit of whack and the disc is off the bolt stub got unscrewed with molegrips.
cleaned up the wheel and put the new sproket on. I was going to use some nice pro bolt sprocket nuts but I orderred the 600R ones and they're the wrong size. I had some new flange nuts which fitted so I used them and sent the others back. The chain tensioner nuts are the same as the sproket nuts and I had some new bolts the originals were bent.
So maybe now onto the frame.
Right then, not much has happened to this, really it's going to be stripping paint, rust killing, prime, paint and laquer.
So to start with
Image Image
Not to pretty huh.
The front subframe stripped and the mirror brace waiting
Image Image
I said this was a dull bit :grin: so rear subframe
Image Image
And clipons
Mean while, after the rust killer.
Exhaustsniffer
Post by Exhaustsniffer »
nice to see it coming along
sportspromatt
Post by sportspromatt »
good to see another one being saved, keep up the great work
another minter for the stable!
hunter
Post by hunter »
Is it finnished yet. :smile:
No - it's a way off being finished :( I'm away to Italy this weekend so not much is going to be done.
But here's a little taster of what's to come
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
Stop teasing me with all this Yama-porn :twisted: :ban:
Get it done Boris :peace:
Hogdigerdy Dog
Bike owned: FZR400RR 3TJ, ZX9R fighter
Post by Hogdigerdy Dog »
Italy, ITALY, when there's a thread to Write :o
come on chap priorities, please ;)
i like the nod to the disc cutter though, sometimes you just gotta get savage with things to get the job done :o
A guy in the garage complex was telling me how I could cut a small slot or use an impact driver (but the allen head was already rounding) I just said "nah mate, angle grinder" .... and had it done by the next day. A grinder is ok if you don't want to mark the disc or disc carrier
