Can you see what it is yet
A couple of weeks ago I picked up a 3TJ in need of a bit .... maybe a more than a bit of TLC
I came with an engine which was taken out to do the valve tollerances and paint the casings. The rest of the bike was going to be done too but the guy's circumstances changed and it didn't get finished. That's why I was travelling over the Dartford Bridge in a transit, still I got it to my garage.
Then I took stock and foun a few bits were missing. Still nevermind, I did think about selling on the 400 engine and dropping a 600 in, I still might, but either way I need to sort out the rolling frame, so I started on the engine
- CRM
Re: Can you see what it is yet
hope this will be ready for friday Boris - c'mon no slacking now you can do it
I bloody can't !!!
				hipringle
- Bike owned: 954 blade,
Oh yes you can.
No - I won't
This is sounding like a marrage ...
Sooo because the engine had the cases off I thought I strip and clean the clutch and got my big boys tools toys out
You have to take care not to drop the clutch's ball bearing because it will drop into the sump. So while I had the sump off I cleaned out the old oil, some gunky looking stuff and guess what ? there was a bearing in there that fitted the clutch, amazing.
Where the engine has stood on an angle water has stayed in the sparkplug holes. Unfortunatley the drain hole on the one side had got blocked up, the plugs looked pretty rough - It took me a while but I got it cleaned out The plugs came out ok though.
				hipringle
Good work mate, it,ll thank you for it later is this going to be a keeper then?
Nope - I've got 2 bikes and that's about right for small amount of time I ride them. I guess if anybody's interested in it let me know and I'll work out a spec for you. Most of it will be done as a matter of course but there's other bits that while desirable won't pay for themselves (braided brake hoses and tyres)
Righto - well here's the cases painted up. I used 5 wheels silver and "PU Laquer" an alloy wheel laquer and it's like spraying glue but thicker - does the job though.
One thing I didn't get right - the new paint reacts with the edges of the old, it goes a bit like paint stripper but only for a millimeter. A bit late for these cases .... hmmm am I going to strip and redo them ... sadly no. When I did the cam cover I used an acrylic primer (use it on plastics before arcylic paint) smell's like model kit glue, anyway it does the trick.
Next bit of spraying will be the the subframes, clipons and yokes - more of that later.
Time to get the cams in.
An engine with the top on
I took most of a weekend to get the cams in checked, out again, move the shims about, in again yada yada. The tollerances are ok at the moment - they could be better but then at £4 a shim they could be a lot worse too.
I've also been swapping bits for other bits ... the fork stanchoins are rusted and a seal has blown. The oil was leaking onto the caliper but the brake pads are nearly finished anyway. The rears are similar and a pad pin is missing.
				Exhaustsniffer
Hurry up and finish it already
