We're there :D
- Deviant400
viewtopic.php?f=62&t=27307
- xivlia
- Bike owned: Ducati 749 D
OKay, i removed my carbs and as you can see one of the cylinders are full of petrol. i removed all my plugs, only the one with the petrol is soaked, the other plugs are dry.
how do i drain this? do i just leave it to evaporate. and i still havent drained that dirty oil in the bike yet, my dad took most of my tools away
oh and also as you can see the cogs and all that stuff is dry, there is not even a trace of oil or lubrication on them.
If its been stood then the oil (thin petrol soaked oil) will drain down to the sump,
- force-v4
Get your self a syringe mate & suck the fuel out.
Or alt. turn the engine over by hand to release it into the engine & then drain it with the oil.
I would say, the syringe would be the better option though.
& also, just give the cylinder head internals a little squirt of something to lube it up.
- xivlia
ah okay, well ive managed to find some tools and drained the oil. i have a large syringe i could use that. but would that get rid of all the petrol? isnt there more right into the cylinder chamber?
Delboy
I've always found that the best way to remove any excess petrol is to use a blow torch, always worked for me...lost a few eye brows along the way though
- force-v4
If you're draining, then, as I say, turn the engine over by hand, so via the side case timing gear, this will open the valves & release the fuel into the engine.
- xivlia
okay thanks i will do that.
- iDemonix
- Bike owned: '92 NC30
Woooh page 100!
I was here, let the legend be told!
