RVF open air box
Re: RVF open air box
Post by Neosophist »
Drunkn Munky wrote:
scooble wrote:I've seen 64hp from the Dynotech dyno on an RVF fitted with a full Ti race system and jetted to suit
What system was that?
Bit small but heres a photo Rick took of Kev (projex) RVF400, runs a Tyga full system. 64.5hp.
His dyno isn't generous with figures either. :)
doodleface
Bike owned: RVF400
Post by doodleface »
Drool
fontyyy
Bike owned: RVF400
Post by fontyyy »
Yep, Kev's bike should go well, better than mine does right now;
Nasty dip there to match the lean patch as well, I know Steve who had the bike before me never put it on a dyno, it looks like no one else ever did either. I struggle to understand ssome people, the bike has had thousands spent on it, FFS spend the last few hundred having it set up properly.
Kev's dyno is a Dynapro, they're not known for being generous with the numbers, his motor is stock (and just 5000 miles old), he's removed the stator, thin race foam filter, 4 short bell mouths, removed the rubber airbox front, stock CDI, full Tyga system.
My old RVF c/w JHA SP1 style pipes, thin foam filter and an HRC cdi made 67bhp on Stephenrc45's dyno.
Tanuki's (same spec but an Ethos full system) made 64bhp on the same dyno but had a couple of bhp more in the mid range. Steve thought the end of the pipe was too small and there were a couple of horses hiding in there somewhere.
I couldn't wait for success, so I went ahead without it.
doodleface
Bike owned: RVF400
I can't wait for my carb kit to come from rick now, you've given me hope the guy who did mine was a cracker. Here's a pic of my race bike btw. Really wanna get this power up n more stable, I think she'll be a beauty when finished. Also... can you get a regular piston refurbishment (piston and rings etc) from rick oliver if its a compression problem?
Cheers again. Booya. Image
fontyyy
Bike owned: RVF400
Post by fontyyy »
RoninZX-10R wrote:I don't have an air filter installed since it's only used on the track, but I think this year I'll secure some sort of fine mesh to keep out any large objects (just in case I crash...again :? )
Mine looks a bit heavy to me
hmmm, it actually looks solid there, full size pic here.
doodleface
Bike owned: RVF400
Wait a sec fonnty, what carb/jet kit are you running? I was thinking of doing a similiar thing and making my own scoop like yours.
doodleface
Bike owned: RVF400
Guys my airbox has no tubes connected from it to the engine, (or anything else) but it looks like the air box cover has male fittings that should have tubes on them to somewhere, (Back of the airbox) but they weren't there at the start. Just wondering if someone could show me a pic of theirs or a pic of how it should be?
Thanks.
James.
fontyyy
Bike owned: RVF400
Post by fontyyy »
doodleface wrote:Wait a sec fonnty, what carb/jet kit are you running? I was thinking of doing a similiar thing and making my own scoop like yours.
If I knew that I'd be a wiser man!
The bike is as it came with no info about what's in the carbs. The A/F meter shows a big lean spot between 11000 and 13000 to correspond with a similar dip in power.
Breathers routed into the airbox.
It also runs an electric fuel pump.
Tomzed
Bike owned: Yamaha wr125x and Nc30
Post by Tomzed »
I have an airbox lid with a pipe exactly like that. That I dont need
I think the one I have still has the breather pipe holes
doodleface
Bike owned: RVF400
Right well I have no breathers connected at the moment, I'll have to get some tube, could that effect my dyno results?
