wheel compatability
hannakournikova
Bike owned: NC30, NC35 & SP2
wheel compatability
Post by hannakournikova »
Royster asked this before, but nothing was conclusive.
Can an NC29 rear wheel be fitted??
hannakournikova
Re: wheel compatability
bump!!
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
Fitted... to what?
I can tell you that with spacers a 29 wheel fits a CB-1 in terms of physically fits and the brake works, but that the chain run will be off. I suspect the wheel alignment will therefore equally be off line. And that it is a swine / not possible to try and get right, so I ended up just changing the whole rear end on my CB. The two swingarms are the same width at the engine, but I think the extra width for the wider wheel is added on the right.
Complicated to explain, but basically an nc29 wheel won't fit in a cb-1, or it will, but it won't line up right.
I think you would have more luck with a cbr600f2 wheel, I believe that fits a cb-1, so should fit your 400sf too?
