Can't get rear wheel off :(
JIGGLYB4LL
- Bike owned: cbr125, NC30
Re: Can't get rear wheel off :(
Bahahahaaaa!!!thunderace wrote:royster81 wrote:This was the problem with my rear end when some bell end didn't cover the hole and the they got filled up.CRM wrote:are we talking front wheel here or rear ?
if rear i bet its been powder coated and then not cleaned up on the mating inner edge which is why its stuck.
will require an abba stand and a couple of mates.
If the front because of non std spacers, then again prise the legs apart and give it a good tug (ooh er missus)
You might want to be a little more specific about which hole got filled up by the bell end
Ah thanks guys, helps to know this doesnt mean the end! It's so discouraging.
Thanks mutton chops, I'll probably take u up on that!! I really appreciate the offer as I don't have one. You're the bestest!!!!
spud
- Bike owned: vfr nc30 1990 , yamaha rs 100
mo haggs wrote:Try puting a block of wood against the inside of the wheel as close to the hub as pos, then hit the wood with a hammer (20oz or lump hammer). Rotate the wheel 90degrees and smack it again, rotate & smack, rotate & smack, ect, ect.
this is what i had to do when i took my rear wheel off , took me a good 10 mins , felt wrong hiting ur wheel with a hammer and a bit of wood though , but it worked ,
sam
JIGGLYB4LL
I'm gonna smack the bloke who sold it to me with a bit of wood!!
Thanks, sounds like a plan, gonna have to be next weekend now
I'll let u know how it goes...lol x
scooble
I had the same problem when I got my NC30. It had been standing for a long time, and the rear refused to come off. in the end I had to use a large bearing puller and got a block machined to react against. It took some considerable effort to get it off, but when I did, the spindle was quite rusty. I cleaned it up with some emery cloth and assembled it all with copper slip.
Malc
- Bike owned: NC35, 5SL, 3XV, 2MA
Devils advocate time... if you've been riding it for a year with no dramas then you've not had anything to worry about!?JIGGLYB4LL wrote:Yeah spesh as I've been riding it since last year unaware![]()
Gutted.
Don't make it right though...
