is it possible?
svsam
is it possible?
Post by svsam »
is it possible to get the carbs on to the engine on my nc24 without taking them apart?
hunter
Re: is it possible?
Post by hunter »
Cocked up so removed. :lol:
hunter
Re: is it possible?
Post by hunter »
If you take them apart you will never get them on,
They fit as one unit.Just remove the complete airbox,fit carbs,then refit airbox.
svsam
Re: is it possible?
Post by svsam »
you mean like the base plate where the velocity stacks come through?
I have everything else off, and can get the back 2 on the rubbers, just cant get the fronts within about a cm of where they should be :S
Cammo
Re: is it possible?
Post by Cammo »
Getting them back on isn't the easiest job first time around.
There's a bit of a knack to it, check out the carb jetting document here for a pointer:
http://www.400greybike.com/docs.htm
If the carb rubbers are the original ones then it might be impossible to get the carbs back on, but give it a good try first.
thunderace
Bike owned: R6, YZF600R
Re: is it possible?
Post by thunderace »
I all honesty, I found it easier to put NC24 carbs back on than any other V4 I've worked on. A rubber mallet helps immensely. Oh, and slacken off all the clamps so the rubbers can move a little :peace:
svsam
Re: is it possible?
Post by svsam »
Feel free to come do mine then :D
I think i'll soak the rubbers in petrol tonight, seems like a plan.
thunderace
Re: is it possible?
svsam wrote:Feel free to come do mine then :D
Where are you based? I'd be happy to help if you're not too far away.
Re: is it possible?
Why soak them in petrol?
Better idea is to get them warm and pliable, rather than stinking of fuel and rank.
I normally get them in to a dush with some boiling water and by the time I've strolled to the garage and got them fitted and clamps on, they are nice and pliable.
small dab of grease and a large dose of brute strength and technique..they'll be on
fujigas1
Bike owned: TOO MANY TO LIST!
Re: is it possible?
Post by fujigas1 »
I always find a little spray of White grease on the rubbers first helps ;) an a few taps with a rubber mallet and their on :pray: Easy peasy ;)
