NC30 Electricals
- bikemonkey
NC30 Electricals
So yesterday I fitted a new end can to my 1992 NC30, no problem with that (the oem pipe was already cut).
And obviously I wanted to hear the sound difference, so I went to start her up and the battery was flat, no problem there. Hooked it up to my trickle charger and left it to charge. Charger fully charged the battery and I put it back in this morning, but when I turned the ignition on nothing happened, no oil light, no neutral light, nothing.
So I checked the fuse box under the pillion seat and they all looked fine apart from two empty fuse slots (second from left and top left as you look at it from behind the bike), but the bike has started and run with no problems before so I don't think that's a problem.
If anyone has any ideas or has had this problem before I'd really appreciate some input and advice/problem solving help!
Only plus side is my new can is shinnyyyyyyyy
Re: NC30 Electricals
not empty slots mate, thats how its made, look at the inside of the fuse box lid.So I checked the fuse box under the pillion seat and they all looked fine apart from two empty fuse slots (second from left and top left as you look at it from behind the bike), but the bike has started and run with no problems before so I don't think that's a problem.
Rick
magg
- Bike owned: VFR400
There is a main fuse as part of the starter solenoid, the contacts for this fuse can become degraded and stop battery power to the ignition switch.
michael760
- Bike owned: NC30 X2 Hornet600 YamSZR660
Sounds like your Battery has died?
Have you tried shorting the battery across the terminals?
Take the battery off the bike and put a spaner from the Pos + to the Neg - and see if it gives a spark?
- bikemonkey
Could somebody tell me where to find the starter solenoid? (first bike ive let myself put a spanner anywhere near)
I had the battery hooked up to my oxford oximiser and it said the battery was fully charged (this was after I took the battery back off the bike just to check I hadnt shorted it somewhere), but I'll stick a spanner across it later and see.
Anymore ideas and advice on fault finding would be well appreciated!
RHS of bike where the rider seat would be (but will need to be removed to access)bikemonkey wrote:Could somebody tell me where to find the starter solenoid? (first bike ive let myself put a spanner anywhere near)
- bikemonkey
Just got in the garage, starter solenoid fuse is fine, and put a allen key across the battery and it sparked nicely.
So back to square one!
- bikemonkey
Nevermind! My dad suggested putting the battery back in and leaving it for a bit, so I went off for a cuppa and came back, now its working! who'd have thought it!
Thanks for your input guys
