engine swop out
blackduck
- Bike owned: cbr400rrj
engine swop out
hi guys,
2nd gear went on the bike late nov, and things being tight money wise thought id investigate myself.....then realised more to it than i could handle...so stopped and put back as it was......now mates sv650 3rd gear went early last year and cost him almost 600 to get fixed...so i thought, buy engine and just swop out!
swoped engine and have it firing as in the manual 1-2-4-3 but sounds rough.... now i realise i may get it balanced but my question is this....would it run in other firing sequence or would it do damage?
great little bike up to now but getting frustrated a bit now....
any help greatly appreciated
blackduck
blackduck
Re: engine swop out
how do you reckon you have it firing in anything other than the right sequence?
blackduck
Re: engine swop out
CMSMJ1 wrote:how do you reckon you have it firing in anything other than the right sequence?
i know i have it firing as said in the manual, and know that it needs to be balanced but out of curiosity was wondering is all?
thanks for the reply
tanuki
Re: engine swop out
Isn't it 1-4-3-2
- petrolhead19
Re: engine swop out
If i remember correctly im pretty sure from left to right of the coils it is 1-4-3-2 as tanuki said.tanuki wrote:Isn't it 1-4-3-2
First coil being 1 and 4 second coil being 3 and 2
Firing order is 1-2-4-3
Also make sure you have the wires going to the coils right, blue/yellow tracer from cdi to 3-2, Yellow/blue tracer from cdi to 1-4 and black/white from cdi to both coils, if i remember the black/white go on right connector and coloured ones go on left connector.
Hope this helps
blackduck
Re: engine swop out
hi petrolhead.....petrolhead19 wrote:If i remember correctly im pretty sure from left to right of the coils it is 1-4-3-2 as tanuki said.tanuki wrote:Isn't it 1-4-3-2
Hope this helps
this is what ive done, and judging by the posts its wrong..... sitting on bike, first coil on left is 1 and 2....second coil on right is 4 and 3.......
so yep i have firing wrong seen firing sequence in haynes manual......wasnt sure it was right as when i stripped out engine ect i wrote down on wall the plugs which were 1-4-3-2......
will swap around tommorrow and let ye know....once again thanks again to everyone for the replies.
- petrolhead19
Re: engine swop out
no problem mate, i have built a few cbr4's, and use to make the same mistake with the firing order of the coils lol.
blackduck
Re: engine swop out
petrolhead19 wrote:no problem mate, i have built a few cbr4's, and use to make the same mistake with the firing order of the coils lol.
sweet as a nut...off for my first spin in a little over 2 months
thanks to all once again
- petrolhead19
Re: engine swop out
glad you sorted it mate :D, it is a bit confusing with them cause they say the firing order in the haynes but they dont tell you which coil goes were lol.
Any more problems will be more than happy to help
blackduck
Re: engine swop out
question for the old hands at these little bikes?
as in title, swopped engine and it is running perfect...went for nice spin........ now my bike is a j (88) while engine is k(89)....... my head scratcher is this.......why when i have my fairing brackets on wont my fairings line up...left and right casings higher up than moulded holes in fairings????
maybe its just me but am i going crazy here....
