RVF 600RR Fork Swap?
ludacris
Bike owned: NC35
Post by ludacris »
Just wondering if anyone has done a fork swap on the RVF with 600rr forks or has any info on how to go about it? Namely forks from the RR5 and later
Work is over for the year and I'm looking at starting a new RVF project that I've been willing myself to do.
Any info and links would be greatly appreciated. Cheers.
Re: RVF 600RR Fork Swap?
have a quick search for venomken's posts...
worth getting them out again, he made a superb RVF
ludacris
Bike owned: NC35
Post by ludacris »
thanks mate...will do :)
i've also been scouring the net trying to find the lengths of both forks with no luck
cajun
Bike owned: MC22, NC29,NC35, 2 FZR400's
Post by cajun »
Venom Ken's is a 30 not a 35. I believe the 35 is a straight bolt on.
ludacris
Bike owned: NC35
Post by ludacris »
cajun wrote:Venom Ken's is a 30 not a 35. I believe the 35 is a straight bolt on.
no its not a direct bolt on as the 600rr has 48mm upper as opposed to the RVF's 50mm upper
cajun
Post by cajun »
Upper? You mean upper triple tree? I'm talking about forks, triples, wheels, clipons, brakes. Everything. I know it bolted right up to my 29.
IIRC you want the upto 07 forks and yokes as the offset is closer to the NC's
ludacris
Bike owned: NC35
Post by ludacris »
yeh I meant the top triple clamp diameters and the top section of the fork outers also.
sorry, I didn't realise that was what you were hinting to...I'm not sure that a complete front end would fit straight on using the 600rr triples otherwise I don't see why Mike at G-Force would go to the trouble of fabbing up custom triples
ludacris
Bike owned: NC35
Post by ludacris »
Drunkn Munky wrote:IIRC you want the upto 07 forks and yokes as the offset is closer to the NC's
you saying theoretically I can use the triples straight from the CBR?
cajun
Post by cajun »
Yes. You can buy the 07 and up triples and they will plug straight into the 35..... Mike at G-Force did that because he was mounting them to a NC30 not 35. The headstock is different. The NC29 (mine) and the 35 (I have one too) and the 07 and up CBR600RR and I believe 05-06 CBR600RR triples all mount straight on. Just mark your forks prior to so you keep the height the same.
