nc30 shock rebuild link
Re: nc30 shock rebuild link
I thin the build you were looking for was Rob - Harkermatic? Have a google on that..not that one?
Otherwise, rebuilding an OEM Showa is a case of fitting a valve to pressurise the system.
Cammo has a rebuilt OEM shock, not by his hands..but might be worth a few pics if he is able?
Why do you want an OEM shock?
pns
Post by pns »
Here in Greece we have only 2 shops for a shock rebuild.I have already try one for another bike and after 2 months the seal was leaking.I know the gas pressure is about 150 psi and the oil should be 2,5w or 5w.After all it's another pleasure to do it yourself :grin: .
magg
Bike owned: VFR400
Post by magg »
pns it can be done at home but you will need to add the valve to the canister for re-gassing and find a supply of nitrogen and gauges. The actual process is not too complicated but unless you intend to disassemble and reassemble the shock on a repetitive basis, the cost of the nitrogen setup makes it a bit uneconomical. You might be able to find a suspension shop that is willing to re-gas it for you but I would make sure I had either my own re-gas system or another source before I started.
pns
Post by pns »
magg wrote:pns it can be done at home but you will need to add the valve to the canister for re-gassing and find a supply of nitrogen and gauges. The actual process is not too complicated but unless you intend to disassemble and reassemble the shock on a repetitive basis, the cost of the nitrogen setup makes it a bit uneconomical. You might be able to find a suspension shop that is willing to re-gas it for you but I would make sure I had either my own re-gas system or another source before I started.
I can re-gas the shock but i don't think it would be easy to find an oil seal where i live.Do you know what oil to use?2.5w or 5w?
magg
Bike owned: VFR400
Post by magg »
You can start with either weight oil and if you do not like the result change it. Just make sure it is specified as shock oil or has a high VI to keep the performance stable. Best bet for a seal would be UK or USA shock shops, many will supply parts if you can provide the dimensions.
pns
Post by pns »
magg wrote:You can start with either weight oil and if you do not like the result change it. Just make sure it is specified as shock oil or has a high VI to keep the performance stable. Best bet for a seal would be UK or USA shock shops, many will supply parts if you can provide the dimensions.
Ok.When i finish my workshop i am going to give a try.I will let you know how it goes :grin: .When you finish the fork you work let us know.Keep going :peace: .
philfingers
Bike owned: NC30 Type 7
Post by philfingers »
I rebuilt the Bilstein inserts in my rally car. it was one of those jobs which people said couldn't be done. I used a refillable valve, a motorcycle derived one, which was inserted into the top of the insert
have a look here, it's the little valve right at the top http://i188.photobucket.com/albums/z143 ... G_0044.jpg
I used 5w oil, for quantity so long as yours isn't leaking then just measure what you take out! Gas pressure needs to be around 150psi. Really you need to use as little as possible. Use too much and you create too much stiction, as a result of pressure on the seals. Too little and you won't hold off the balance piston and the oil will aerate.
I used a gas needle refill kit. It's bascially a hyperdermic needle, which you use to fill the gas with through the valve. Once you pull the needle out the valve seals, they'll hold something like 100bar.
I used argon instead of nitorgen but any suspension specialist will refill it for a small fee.
If you want it rebuilt, then www.revsracing.co.uk will do it. I've used John for years, he's good and will rebuild your unit. He did a GSXR1100 for me a few years back and charged me £100 and that included making a new pistons shaft as mine had pitted and was causing the seal to be damaged
If you need pictures of the seal let me know, also I can show you the needle kit if required
I used one of these to refill mine http://www.dirtbikebitz.com/motion-pro- ... -9760.html (good safety galss required if playing with compressed gas and needles!)
This looks interesting http://books.google.co.uk/books?id=GWR_ ... &q&f=false
pns
Post by pns »
philfingers wrote:I rebuilt the Bilstein inserts in my rally car. it was one of those jobs which people said couldn't be done. I used a refillable valve, a motorcycle derived one, which was inserted into the top of the insert
If you want it rebuilt, then http://www.revsracing.co.uk will do it. I've used John for years, he's good and will rebuild your unit. He did a GSXR1100 for me a few years back and charged me £100 and that included making a new pistons shaft as mine had pitted and was causing the seal to be damaged
I know it wont be that difficult.Unfortunately i live to Greece so i cant use the shop you recommend.I could rebuild it at a shock shop but i want to do it by myself and i hope to learn a few things.If i need any photos or help i will let you know.Thanks :peace: !
philfingers
i just looked at that book i linked to. It's looks really interesting, so I ordered a copy, will let you know what I think when I get it
vr46
Bike owned: All sorts
Post by vr46 »
Practical Sportsbike magazine; I'm not sure which issue it was, but I think there is an article on "How to rebuild a shock" with step by step photos.
