GK76a rear shock and swing arm
matttaylor69
- Bike owned: 1990 Suzuki GSX-R 400 GK76a
Hi does any body know weather there is any good newer rear shocks that are a straight swap for the GK76a? Also does anybody know how hard it is to fit a GSXR 600 K6/K7 swing arm to a GK76a?
Matt Taylor
Matt Taylor
ben2306
- Bike owned: gk76a
Re: GK76a rear shock and swing arm
i'm also hoping to know whether there's any other model, direct fit for rear shock?
Andy
- Bike owned: R1x2 98/2k/Gp125/73a/76a/76a
Almost straight swap is the k6/k7 shock,just turn the top mount on the 76a upside down to keep suspension geo right and space the dog bones with correct size washers to clear the spring on the heavier shock...easy. If you insist on fitting a braced swingarm why dont you use a 73a braced arm which is a direct fit,saves a load of time and head scratching.matttaylor69 wrote:Hi does any body know weather there is any good newer rear shocks that are a straight swap for the GK76a? Also does anybody know how hard it is to fit a GSXR 600 K6/K7 swing arm to a GK76a?
Matt Taylor
Andy
Jaicen
- Bike owned: GK76SP & ER6F
K7 shocks drop right in. I left my top mount in place to be sure the top clears the battery box. Possibly raises rear ride height, so that's not usually a bad thing
kiwirider
I have recently had success with a 2007 ZX10 rear shock in my gk76 race bike. Bolted straight in, only had to do a slight mod to the airbox as the shock reservoir presses up against the bottom of the airbox. Works good. Not sure if battery box would be in the way on a standard bike though.
