URGENT HELP!! Fuel in vacuum line!!
spongy.bob
Post by spongy.bob »
Hi All,
for various reasons, I've cocked up and put fuel in the vacuum line while fueling from a funnel with the tank off.
Appart from swearing a lot, what should I do??????????????
thanks, Rob.
arsey30
Bike owned: ftr223 650 bros
Re: URGENT HELP!! Fuel in vacuum line!!
Post by arsey30 »
How much fuel is in the cylinder?
Remove that plug [number 3] and turn the engine over by hand, then spin the starter with kill switch off, just a quick dab at a time to expell the fuel into the exhaust port and out of the plug hole.
Then spin the engine a few times.
Clean the plug, refit and turn engine by hand, before starting.
Check oil level for any increase level and smell of fuel, if in doubt change the oil when you get engine running.
That is a new one on me Bob!
Like Dave says..get the fuel spat out and ensure you've not got a load in the sump
spongy.bob
CMSMJ1 wrote:That is a new one on me Bob!
I know, it took real effort to be that stupid!!!
not only that, but I rounded off the socket fitting on the inspection cover!!?? Mr Oliver has a new one in the post for me though, and I'll be changing the oil anyway.
Silly boy. :ban:
porndoguk
Post by porndoguk »
provided there isnt LOADS of fuel, turn the engine over by hand, it should push it out into the exhaust, then remove the plugs to let the remaining petrol evapourate off the plug/s and cylinder/s
Rick
