Oil on the spark plugs
alexandervf
- Bike owned: NC35
Hi everyone,
I have 2 issues with my nc35.
The first is that i smell unburnt gas coming from the exhaust.
The second and the most critical is that the spark plugs are covered with oil.
Can you please tell me what seems to be the problem? And what parts do i need to replace in order to stop the spark plugs from getting wet by oil?
Alex
Alex
Re: Oil on the spark plugs
Running too rich? Too much petrol getting in causing wet plugs...alexandervf wrote:Hi everyone,
Alex
alexandervf
- Bike owned: NC35
Don't know....I will check that.
Thanks Neo!
Thanks Neo!
You can often get some on the threads and it looks like it is oily..but it is normal. we had a chap not long back posted the same. I pulled some plugs and we compared...a little oil is alright
On the ceramic and possibly threads this is normal, most deeply recessed plugs have this.
However, if the tips are wet (which I assumed) then it could be fuel residue, combined with the smell of fuel this is the assumption I took.
If you can smell fuel out the back then it isn't getting burned, which means there is excess, some of which could be ending up on the plugs!
hardnutdvd
- Bike owned: RVF400 NC35
that chap asking before was me..
does yours looke like this
i was very worried until i had some reassuring words from knowledgable members on here.
alexandervf
- Bike owned: NC35
I guess you are right. As long as i can remember, i have always found oil/fuel deposits on the threads of the spark plugs. The thing is that this time there is too much of this stuff on the plugs.CMSMJ1 wrote:You can often get some on the threads and it looks like it is oily..but it is normal. we had a chap not long back posted the same. I pulled some plugs and we compared...a little oil is alright
One thing i have not mentioned until now, is, that a few months ago i did an overhaul in my carbs. Thorough cleaning and a lot of o-rings replaced with new ones. Maybe, as neo said it is running rich and needs adjustment.
alexandervf
- Bike owned: NC35
Yes neo you assumed correct! The thing that worried me most was that they (three of the plugs) were excessively wet than i was used to, so a lot of bad thoughts came from my mind such as piston rings,valves and other stuff.Neosophist wrote:On the ceramic and possibly threads this is normal, most deeply recessed plugs have this.
Another thing that i noticed is that the oil level was at the lowest point of the stick.
Don't know really. I also noticed that the fuel pump was not working properly (fixed that, so now there must be the correct amount of fuel running into the carbs).I will be watching it closely from now on, see how it behaves.
alexandervf
- Bike owned: NC35
Hmmm, yeshardnutdvd wrote:that chap asking before was me..
alexandervf
- Bike owned: NC35
Thank you all for your replies!!!
