something came loos
MK88
something came loos
Post by MK88 »
Morning To all
Sorry for the bad English I can not type in full when I type from my cell phone that is why I short type
But let’s try it again. I set the Valve Clearance with the help of vipper’s blog Took the bike out for a ride the performance was great far better then before as I came to a stand still it sounded like something came loos in cylinder 1 & now I am to scared to start the bike again don’t want my motor to jam up. I now have a shutter noise in Cylinder 1 and 3 It sounds like a tapping sound. Mechanically I am not bad but I don’t now much about bikes I took my bike to several garages and every time they say it is right it still doesn’t have any power. So I decided I will look at it myself so after I decided to check for valve clearance as that was my last option. I did change the valve clearance and for the first time since I owe this bike it idled on its own. There was definitely more performance and a big difference in the bike except for the tapping noise. I don’t now what to be looking for as I said I am not that good with bikes but I am learning as I go Thank you all for the replies
Man_Named_Dave
Bike owned: NC30(K)
Re: somthing came loos
Post by Man_Named_Dave »
What.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
WTF - gansta innit
MK88 you will be pleased to know we dont limit posts to 160 characters, nor do we charge per post, and as most of us are above the age of 18, the above written in english will return far more respect and serious responses
jim157
Admin NWAA
Admin NWAA
Bike owned: A few small ones
Post by jim157 »
AUTOEXEC.TWAT
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
Take the cam cover off and have a look.
If the engine ran for a while, unlikely a shim came out, unless your mechanical ability is no better than your command of English, and it was not located correctly [tilted] or not there in the first place, in which case the measured clearance would have been way out.
Hadies
Post by Hadies »
Do you spreak ingrish?
callboy
Post by callboy »
get a hammer and bash the head with it... then do this too your bike
porndoguk
Post by porndoguk »
this may also help with your engine troubles
CLICKY HERE - eBay BUY it NOW
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
:plus: innit :grin:
Deviants AM/PM build
viewtopic.php?f=62&t=27307
Post by Neosophist »
Typing aside.
A shutter noise... interesting.
Could be the shim came loose and now the rocker is smacking the valve (your valve might drop out if this is case)
Did the bike run any worse when this happened?
It could be a fault with valve cleanence with being too loose or too tight. Did you change the shims in this cylinder?
Take the rockerbox off and have a good look, make sure everything is there and there is no signs of wear on anything and measure the clearances.
Did you do them properly? Rotate the cam into the correct position etc?
