CBR 400 - nc23 Speedo Cable Installation
Rochana
Post by Rochana »
I recently bought a cbr 400 bt the speedo wasn't working.. upon inspection i found that the cable was broken from the sprocket end.. it still had the metal part of the cable in it.. i dont know how to install the new cable i bought.. should i take it to a garage ? i did a bit of googling .i can take the front fairings off and connect the cable to the speedo.. bt dont know what to do with the other end .. :S
i know it should go in this.. but how to do it exactly.. can any one help me with this.. pics or a video wud b great :)
Yakama
Re: CBR 400 - nc23 Speedo Cable Installation
Post by Yakama »
Here you go this should help:
leopard_pagan
Bike owned: CBR400/600 Fighter
Post by leopard_pagan »
& a tip that haynes doesnt say.....
BEFORE you start pulling the cable out..
tie a sturdy bit of string to one end of the cable.
pull the cable out from the other end leaving the string in the cable routes place.
now tie the same bit o string to the new cable end.. use the string to pull the new cable back through the original routing..
viola.. solid way of routing sorted, just re-attach new cable.. done..
Rochana
Post by Rochana »
A littles problem tho.. the part where the cable fits on my bike isnt as same as the pdf u'we put.. it doesnt have two bolts you see.. i'd have to take that whole triangular thing out.. it has 3 , 8mm nuts around the whole thing.. the things is , are there small wheels in it ? If i take the whole metal thing out can i remove the old broken cable and install the new one and stil put the whole thing back together ? the thing is .. i dont know wats inside that metal thing :S
