VFR400 OIL LIGHT and braded lines
GIXERMARK0
HI brought a 1995 vfr400 a couple of months ago cracking little bike
unfortunatly i wrote of my gixer600 k2 race bike thats why iv got this as im nearly 50 and the old legs are playing up
any whay i have changed to a 17inch back wheel raised the back rebuilt the forks (rick oliver :))
took the bike out to day and once warm the oil light comes on at tick over and goes off at about 4-5k and stays off
but comes back on and stays on at tick over
its had a full service with siloline comp 10w40 so is this oil the correct grade or do i need another grade
or other fault
oil pressure switch
oil pump
bike runs fine sweet as a nut just dont want to ride it just in case it goes bang
my other question is with sp2 calipers and a gixer radial master any one know who can moke brake lines up
cheers mark
or other fault
oil pressure switch
oil pump
cheers mark
Delboy
Re: VFR400 OIL LIGHT and braded lines
Oil viscocity is correct, is it semi synthetic?
I think you've answered your own questions as though you now what could be the cause of possible low oil pressure.
Try changing the oil pressure switch as a cheap 'fix' other wise it's the oil pump.
GIXERMARK0
HI NO its fully synthetic
Delboy
As long as it's bike oil specific and not car shouldnt make a difference to low oil pressure.
GIXERMARK0
hi
definatly bike oil
iv seen the results of an engine run on car oil (not nice)
i forgot to mention the oil light never came on with the old oil
right off to find a pressure switch
thanks mark
definatly bike oil
thanks mark
Delboy
As for your lines, I use Pirtek, take your old fittings along and they can make anything fit anything
GIXERMARK0
pirtek are they in coventry ?
Delboy
They are UK national, the company I work for use them.
Try these .......... http://www.pirtek.co.uk/service-centre- ... entry.aspx
Might not be the cheapest but I have never had a problem with quality.
GIXERMARK0
thats brill just up the road :)
Chrissy_J
- Bike owned: VFR400Z NC21
If the oil light is working it means the switch is operating, but at the wrong time. If you're certain you don't have a leak, and that you aren't burning oil, it's possible that the oil thins excessively when it's warm... it works and it's not damaging the engine, but the switch can't 'see' it, if that makes sense.
Someone in the trade told me that older engines shouldn't be run on full-synth oil because of this reason- the engines are sufficiently low-tech enough to use standard or part-synth oil because it's just... denser, or something...
Whatever, I'm sure someone here has a better explanation.
Before you start pulling it apart, is it worth draining the oil (keeping it safe for refilling) and replacing it with some cheap stuff? Just as a trial, like...
Also, I've had brake and clutch lines custom-made by Earl's, they're pretty damn good IMO...
Earl's custom brake hose creator
