crankcase breather, where the f is it?
oldgreyandslow
Bike owned: 1990 NC30
Post by oldgreyandslow »
Looks like the previous owner overfilled the oil in my bike, why didn't I check it!
Seem to have a lot of white smoke from the exhaust, so I've drained the oil and it looks like I'll be doing more initial work than I thought, however Haynes says the crankcase breather may be blocked too, thing is, it doesn't say where it is!
So someone please enlighten me.
Also any other potential problems from too much oil?
Ta
porndoguk
Re: crankcase breather, where the f is it?
Post by porndoguk »
breather is on the top of the rear cylinders rocker/camshaft cover, and the hose connects to the Airbox,
Delboy
Post by Delboy »
Didnt you fit a pipercross filter or summat Rick?
porndoguk
Post by porndoguk »
vfrderek wrote:Didnt you fit a pipercross filter or summat Rick?
yeah i had 2 spare piperX filters i had from an old car, i gave the other to curt,
doesnt make any noticible difference but i guess in theory it should help, and maybe lower emissions! after all only clean air is going into the induction and not dirty oil vapour,
stevie
Bike owned: 92 uk model nc30
Post by stevie »
http://i429.photobucket.com/albums/qq12 ... C00212.jpg
if iv done this rite there should be a picture of my carbs above that showes the crank case breather just to the rear of them on the rear cam cover, its the bit with the small k&n filter on it, youres will have a hose conected to the air box, hope this is of some help.
hunter
Post by hunter »
If it's overfilled with oil it will blue smoke,White smoke is water,headgasket.
oldgreyandslow
hunter wrote:If it's overfilled with oil it will blue smoke,White smoke is water,headgasket.
I bloody hope not!
hunter
Post by hunter »
I hope not to,But that's the norm.
Post by Neosophist »
hunter wrote:I hope not to,But that's the norm.
Indeed... is it whitesmoking constantly / a lot?
What does the oil look like, have you took the rad-cap off and have a look in there, whats the water look like, any oily droplets? are you loosing water?
Could just be a lot of condensation in the air.. these bikes take a while to warm up fully.
Ditch the oil and coolant and refil from scratch and keep an eye on them.
And it'd be worrying if its the h/g... these bikes are uber reliable even when seriously abused / neglected.. after years on 400 forums i've never seen anyone change vfr head-gaskets
porndoguk
Post by porndoguk »
im changing mine next month :P
to accomodate for the tidier heads i have from geoff.
