Checking oil level on the dipstick?
Spoilt01
- Bike owned: Current : VFR NC30
Hi Guys,
What is the correct way to check your oil level on a NC30? Im not sure if I should:
1. Turn the dipstick in till its closed/locked and then turn back out again?
2. Once turned out/open just dip it in the hole and then remove?
Reason being once the bike is upright of course, if I use method 1 then the level is correct but if I use method 2
then it is incorrect/low.
Your help will be much appreciated Thanx
Re: Checking oil level on the dipstick?
Method 2.. bike upright, take the stick out, clean it, place it back on the threads and whip it out again..
Spoilt01
Thanx alot for the quick reply, will check again later but def need to top up on oil...
