NC23 rattle at 4/5/6k revs
micklewright
Bike owned: RSV 1K, CB600, GSXR X2 TRACK
Re: NC23 rattle at 4/5/6k revs
Post by micklewright »
I got a length or rubber hose and cut it along the centre and then fitted around the tank edges. Not the prettiest but fine for track and saves dropping those pesky rubber blocks all the time!
DK-Tandy
Bike owned: CBR400RR NC23
Post by DK-Tandy »
i never though they had rubber on the sides, all the tanks on ebay dont have rubbers.. i was going to put rubber under the bolt on the frame so its heightened a few mm, along with the rubber around the bottom where the seat bolts on, it should just stop the rattle and make me less paranoid :D
Adrian89
Bike owned: NC23 and '05 Blade
Post by Adrian89 »
There definitely should be a piece of rubber that almost completely wraps around the tab at the bottom of the tank that is held on with the same bolt that holds the seat on, as well as a thick piece at the top bolt (near the top yoke) and there should also be 2 pieces of rubber preventing the sides of the tank from touching the frame.
Adrian
Wozza
Post by Wozza »
Dan, as Adrian says - you need rubbers on the sides. Fitting extra rubber at the front and rear won't fix it!
With the Honda side blocks you do need to glue them onto the tank.
DK-Tandy
Post by DK-Tandy »
ahh, well i never knew that :)
i fitted an extra rubber where it bolts near the yoke and its fixed all the issue for now.
when i have some spare ££ i'll get the new rubbers
petrolhead19
Bike owned: 2 x nc23's 1 x nc29
Post by petrolhead19 »
you can see the rubber strips in question on my pic here :D, i might have some lying around you can have ill have a look later
http://sphotos.ak.fbcdn.net/hphotos-ak- ... 4091_n.jpg
Cheer
Adam
Wozza
Post by Wozza »
They're not the Honda rubber blocks but anything like that will do the job.
DK-Tandy
Post by DK-Tandy »
i might be able to get some rubber from my dad or mate
angry_rob
Post by angry_rob »
DK-Tandy wrote:i might be able to get some rubber from my dad or mate
I tried very hard not to troll on that. :twisted:
I got my tank rubbers from David Silver Spairs, but they are completely overpriced for what they are so I guess this is pretty useless comment for you.
Anything that makes a snug fit will be fine.
DK-Tandy
Post by DK-Tandy »
:oops:
