NC30 Sprocket Bolt/Studs
Delboy
Re: NC30 Sprocket Bolt/Studs
Post by Delboy »
Sounds fooking good, is it a 'well ard' finish then to do the nuts, not to chip when torquing up?
I'm interested :ugeek:
porndoguk
Post by porndoguk »
vfrderek wrote:Sounds fooking good, is it a 'well ard' finish then to do the nuts, not to chip when torquing up?
Well ill be torqueing up with insulation tape wrapped around them just incase but its should be a solid finish you only get chiping etc is the surface chromed onto was clean when they went in, ill assume after my polishing efforts they will finish off anything they deem to be errornous, i doubt theyd want complaints etc.
Delboy
Post by Delboy »
Get some pics up when ya done Ricksta :peace:
