NC30 Sprocket Bolt/Studs
i fancy buying some new sprocket bolts/studs seeing as im swapping my sprockets
only ones i can find are these.
https://www.tastynuts.com/Products/VFR4 ... h/TISPHO19
as always EXTORTIONATLY priced, and there Ti, id be happy with just stainless steel where else can i buy these at lesser the cost of ripoffnuts.com
Re: NC30 Sprocket Bolt/Studs
Mmmm Ti is tasty!
David Silver has standard bolts listed for £2.50.
http://www.davidsilverspares.co.uk/part ... 120MR8000/
i got the standard ones, i want stainless of some sort, ive worked out if it buy m8 a4 Hex 13mm Head the flat side will slot up against the groove i will need to machine/grind the face off a few mm but im going down that route i thinks.
Delboy
Rick they are £28 collected
Other wise like you say, get some stainless bolts and cut them down, not a great feat, use the old ones as a template.
i bought 10x Stainless Steel A2 M8 13mm Hex bolts, will grind the heads down so they about 2.5mm thick. will do the job nicely. for the grand sum of £1.70vfrderek wrote:Rick they are £28 collected![]()
Delboy
im also taking a ruck of metal parts to a chromers in walsall later!
so gonna get my old ones black chromed :D
- STYLER
Sounds good! id like to see some pics of your bolts before/after grinding/fitted.... on and the chomes parts too!
Delboy
Oooooo wot you getting chromed?!?!?!
25 partsvfrderek wrote:Oooooo wot you getting chromed?!?!?!
6 x sprocket bolts,
1 x hub nut (46mm)
1 x hub washer
2 x stem/yoke nut (41mm)
2 x wheel nuts (36mm) ones marcus57's on loan :)
1 x clutch bracket off the side of the engine above gear box.
1 x clevis pin
1 x clevis
1 x hub pinch bolt (17mm)
Various head bearing bits locking/castleated nuts
Various Torque arm bits thats are mild steel
being charged £20 cash for 25 bits in satin chrome i found them down in walsall "ACF Howell"
will let you know how i get on, they did quote £35 for the full on shinny stuff but i told them i dont want it shiny shiny, just want a dull protective finish, they said to get hi chrome the parts all have to be polished first etc which takes more time. and money
