RVF Carbs on an NC30
- Smev
- Bike owned: NC30 of course
For those people who have done this modification - what have you done about the choke?
Did you use the NC30 choke lever and cable or did you replace it with the RVF one?
If you replaced it with the RVF one - how and where did you mount it? (as its a shorter cable with a push/pull circular bit that is normally up on the bars!- the NC30 one is connected to the lever down in the infill panel)
Cheers for any help!
Mister Donut Rep NC30
Re: RVF Carbs on an NC30
Cant help you there mate, i always bin the choke cables and put a tie wrap around the choke mechanisum which sticks out just above the frame. Every choke cable ive had plays up in one way or another, hate em.
Can you not just get a choke mount for a 35 and fix that to the 30 frame?
Drunkn Munky wrote:Cant help you there mate, i always bin the choke cables and put a tie wrap around the choke mechanisum which sticks out just above the frame. Every choke cable ive had plays up in one way or another, hate em.
Me too...racer chic
Genius idea, im going to do that as my nc30 choke is a little dodgy, even after replaceing with a newer one.Drunkn Munky wrote:Cant help you there mate, i always bin the choke cables and put a tie wrap around the choke mechanisum which sticks out just above the frame. Every choke cable ive had plays up in one way or another, hate em.
tony you get the GEEK crown today my friend :)
You have to stand there and hold the choke for 30 secs when its cold but i just do that then crank the idle speed up a little a leave it to warm up.
The choke on 35 carbs has got a locking mechanisum on it so you just pull it out and leave it, to release it just give it another tug.
is the nc30 one meant to just close after its warmed up?Drunkn Munky wrote:You have to stand there and hold the choke for 30 secs when its cold but i just do that then crank the idle speed up a little a leave it to warm up.
im still gonna have a cable and lever, im just gonna ad a cable tie because you never know.
- CRM
- royster81
Same here as I didn't want a hole in my left hand infil panel.....
- Smev
Thanks for the replies - I'm glad that the vfr one fits, as it'll look better overall, and doesn't require me to make or modify any brackets!
Cheers guys!
Cheers guys!
