Coolant Levels and Reg/Rec wiring
Man_Named_Dave
Bike owned: NC30(K)
Post by Man_Named_Dave »
Hi guys,
I just re-attached my radiators and put 2 litres of correct coolant into the NC30. However, I had a little leak where I had to tighten the thermostat bolts. The reservoir level has dropped a little below the lower line.
Will this be ok to ride tomorrow, or should I get another 500ml in there before I ride anywhere?
Last edited by Man_Named_Dave on Fri Mar 18, 2011 6:35 pm, edited 1 time in total.
uber pikey
Bike owned: NC30, GS700e GSX750 katana pop
Re: Coolant Levels
Post by uber pikey »
The only way to check for sure is to run it, and keep an eye on the temperature. It will need to operate the thermostat at some point so it might be worth keeping some water with you and take it for a ride. Is the rad full? It should be and as long as the temperature remains stable then all should be fine.
I saw it so I took it!
Man_Named_Dave
Bike owned: NC30(K)
Re: Coolant Levels and Reg/Rec wiring
Cheers Pikey.
However I've now made the mistake of checking my reg/rec connections and have now put them back wrong!
They're not on a plug so does anyone know which way they go? The 3 yellows on the small connectors, I assumed, but I've tried the red and green both ways round and I'm getting no power.
I know it looks messy!
uber pikey
MEDIC
Man_Named_Dave
Bike owned: NC30(K)
I know, but it started fine this afternoon!
thrasher
Bike owned: nc30
Post by thrasher »
you will have blown your main fuse by getting positive and negative wires mixed up lol
connect all 3 yellow wires on bottom "doesnt matter which order".
then connect positive "red/white" on left and negative "green" on right and change your spade fuse 30amp
Man_Named_Dave
Bike owned: NC30(K)
thrasher wrote:you will have blown your main fuse by getting positive and negative wires mixed up lol
Which fuse is this, Thrasher? I can't see any 30amp fuses on the wiring diagram or fuse box itself.
It is in the starter solenoid thingy - right hand side of the bike, unhook the main fuse thingy and it is in there.
uber pikey
This might be the one on the right hand side of the subframe just to the side of the battery mate.
Beaten to the post again, damn you fast typers....
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Post by hardnutdvd »
all the fuses are located in the fusebox under the rear seat. except the main fuse... this is integral with the starter relay which is located on the right hand side of the bike, just ahead of the coolant bottle ;)
edit.. you may be slow typer pikey, but still faster than me :grin:
