Coolant Levels and Reg/Rec wiring
- Man_Named_Dave
- Bike owned: NC30(K)
Hi guys,
I just re-attached my radiators and put 2 litres of correct coolant into the NC30. However, I had a little leak where I had to tighten the thermostat bolts. The reservoir level has dropped a little below the lower line.
Will this be ok to ride tomorrow, or should I get another 500ml in there before I ride anywhere?
Last edited by Man_Named_Dave on Fri Mar 18, 2011 6:35 pm, edited 1 time in total.
- uber pikey
- Bike owned: NC30, GS700e GSX750 katana pop
Re: Coolant Levels
The only way to check for sure is to run it, and keep an eye on the temperature. It will need to operate the thermostat at some point so it might be worth keeping some water with you and take it for a ride. Is the rad full? It should be and as long as the temperature remains stable then all should be fine.
I saw it so I took it!
- Man_Named_Dave
Re: Coolant Levels and Reg/Rec wiring
Cheers Pikey.
However I've now made the mistake of checking my reg/rec connections and have now put them back wrong!
They're not on a plug so does anyone know which way they go? The 3 yellows on the small connectors, I assumed, but I've tried the red and green both ways round and I'm getting no power.
I know it looks messy!
- uber pikey
- Man_Named_Dave
I know, but it started fine this afternoon!
- Bike owned: nc30
you will have blown your main fuse by getting positive and negative wires mixed up lol
connect all 3 yellow wires on bottom "doesnt matter which order".
then connect positive "red/white" on left and negative "green" on right and change your spade fuse 30amp
- Man_Named_Dave
Which fuse is this, Thrasher? I can't see any 30amp fuses on the wiring diagram or fuse box itself.thrasher wrote:you will have blown your main fuse by getting positive and negative wires mixed up lol
It is in the starter solenoid thingy - right hand side of the bike, unhook the main fuse thingy and it is in there.
- uber pikey
This might be the one on the right hand side of the subframe just to the side of the battery mate.
Beaten to the post again, damn you fast typers....
- Bike owned: RVF400 NC35
all the fuses are located in the fusebox under the rear seat. except the main fuse... this is integral with the starter relay which is located on the right hand side of the bike, just ahead of the coolant bottle
edit.. you may be slow typer pikey, but still faster than me
