Nc23 question
aaron0288
Nc23 question
Post by aaron0288 »
Looking at a nc23 with a snapped choke cable. Do they start ok from cold with no choke?
Re: Nc23 question
There will be a knack to it... Can you not get a ziptie around the mechanism and use that to pull it open??
aaron0288
Re: Nc23 question
Post by aaron0288 »
I dont know nc23's so you'll have to tell me :)
Re: Nc23 question
lol.neither do I..but you know the choke is a cable activated linkage. On ym 30 I use a zipt tie, on the actual linkage, to pullt he linkage instaead of using a choke mechanism.
The linkages are easy to get to..so try it ;)
If not, a sniffy sniff of throttle might get it going.or some easy start/carb cleaner sprayed in it..
Yakama
Re: Nc23 question
Post by Yakama »
Yeah I did the same on my NC29 carbs lift the tank up to get access to the carbs and then put a bit of wire attached to the choke mechanism with a washer on the end hanging out the side of the bike and hey presto
aaron0288
Re: Nc23 question
Post by aaron0288 »
I'll give it a try; if I get it. Cheers guys.
Yakama
Re: Nc23 question
Post by Yakama »
Attach the wire to the black arm my finger is pointing to on the carbs:
veefer400
Bike owned: Ducati 900SS, 1978 Cafe 400/4
Re: Nc23 question
Post by veefer400 »
** NC23 choke cables are discontinued by Honda, DSS etc...
Best hope you can get one on ebay? The cable was broke on my Triarm when I got it? :smile:
DK-Tandy
Bike owned: CBR400RR NC23
Re: Nc23 question
Post by DK-Tandy »
im sure there is another bike which uses the cable and the metal bloack end? its similar to the clutch cable on a ApriliaRS50 just the aprilia one is thinner?
just a suggestion though?
brmoore
Bike owned: 125/250/400/600/1000
Re: Nc23 question
Post by brmoore »
I know this is an older topic, but the pictures will help I've got the fuel tap left to take off and airbox then I'm replacing my choke cable and I have ordered a brand new OEM choke cable?? So how hard to get are they? lol...
Hopefully it arrives but I've seen a few other places also listing new choke cables for NC23
