rvf trackbike dash problems
buntz
Bike owned: nc30 3tj
Post by buntz »
hi all i'm looking to swap the stock (damaged) speedo tacho and temp gauge for an aftermarket (alfano) digital dash.
i had all kinds of problems with my 3tj and removing the speedo, does anyone know what i'm likely to run into on the rvf?
cheers buntz
Re: rvf trackbike dash problems
dead easy mate, all digital dashes ive come across work straight off the cdi
buntz
Post by buntz »
the problem i had before was with the bike registering that the speedo was missing and restricting the power after second gear, finally cured it with an m max type box, wondering if the honda will be the same?
No need for the m max box you just need to connect the rev limit wire from the cdi to a +12v source if you remove the speedo
buntz
Post by buntz »
ideal, now to save a search does anyone know which wire this is from the cdi? i know it'll be on here somewhere but any pointers much welcomed
Orange with a blue tracer ;)
LOL - you are good DM
:geek:
buntz
Post by buntz »
thanks mr munky you are a gent
i'll let you know how it goes
buntz
:lol: Been there done it :twisted:
