Is it common for vfr's not to find neutral...
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
Re: Is it common for vfr's not to find neutral...
It's normal.
- uber pikey
- Bike owned: NC30, GS700e GSX750 katana pop
- Muttonchops
- Bike owned: current:nc30, cbr900rrx, xt350
I hope it's normal as I have to blip the throttle too!
I took an IQ test and the results were negative.
sotto
Which means I don't even have to check the basket (I'll check it anyway) cos it does that from time to time. It's like the bike wants to inch forward with the cluth disengaged, damn, looks like I have my work cut out for me. I guess the next step is to get a clutch rebuild kit? Or is there another route to pursue?arsey30 wrote:If the clutch basket is worn, the clutch will drag and try to pull the bike forward when in gear with the clutch lever pulled in i.e disengaged.
If it does not, and you can let the clutch in [lever] part way without it engaging, then the basket is not the problem.
Dave.
arsey30
- Bike owned: ftr223 650 bros
Check cable free play first.
You may be able to file any grooves out if not too deep, have a look before buying another basket.
Fit a new cover gasket and main shaft lock nut, a peg [catle nut] spanner is needed.
Dave.
Dave.
sotto
Thanks Dave sounds like the lesser of the evils. Will give it a go.
- thunderace
- Bike owned: R6, YZF600R
I've never had an issue finding neutral on my NC24....
Totally different gearbox and clutch.thunderace wrote:I've never had an issue finding neutral on my NC24....
The NC30 has a stupidly long first gear
Perhaps there all worn inside? 24 gearbox should fit if you want more evenly spaced gears
sotto
