my vfr 400 nc30 project
reverse cylinder jim
Re: my vfr 400 nc30 project
marcus57 wrote:I have ordered a set from him , is inner to inner the correct way to measure rims?
Would have thought so as thats where the tyre will be seated. Ive always measured mine that way
James
marcus57
Post by marcus57 »
spared 10 kins in the garage before tea, looks close but i might be able to get away with it. i will get my dad round as this is his sort of thing to play around with
i will be gutted if they dont fit as i love them, front also seems to be quite straight forward.
Is that rear sitting flat against the hub?
marcus57
Post by marcus57 »
Drunkn Munky wrote:Is that rear sitting flat against the hub?
Yeah , it was quite hard to get it in place and take a photo, can you see an issue?
marcus57 wrote:Yeah , it was quite hard to get it in place and take a photo, can you see an issue?
errr yea, the axle isnt sticking far enough through the wheel to get the spacer and nut on.
Try and find a centre point on the subframe and see if it lines up with the centre of the wheel. Isnt there something called offset? or is that just for car wheels? Im sure if the offset is wrong then the wheel wont sit centre on the bike.
Dont quote me on this tho i just vaugly remember something along them lines
marcus57
Post by marcus57 »
No that does make sence , like I say my dad is really good with this sort of thing so I will let him have a look at it , will be gutted if they don't fit
porndoguk
Post by porndoguk »
marcus, pop to a local bike garage and ask them to fit a knackered tyre so you can try it for size?
marcus57
Post by marcus57 »
porndoguk wrote:marcus, pop to a local bike garage and ask them to fit a knackered tyre so you can try it for size?
thats another thing on my to do list, its going to be bloody close , if i do have to sell them at least i will be able to afford to have it painted
porndoguk
Post by porndoguk »
could always do a swing arm conversion!
marcus57
Post by marcus57 »
:o
