my vfr 400 nc30 project
reverse cylinder jim
Re: my vfr 400 nc30 project
Would have thought so as thats where the tyre will be seated. Ive always measured mine that waymarcus57 wrote:I have ordered a set from him , is inner to inner the correct way to measure rims?
James
marcus57
spared 10 kins in the garage before tea, looks close but i might be able to get away with it. i will get my dad round as this is his sort of thing to play around with
i will be gutted if they dont fit as i love them, front also seems to be quite straight forward.
Is that rear sitting flat against the hub?
marcus57
Yeah , it was quite hard to get it in place and take a photo, can you see an issue?Drunkn Munky wrote:Is that rear sitting flat against the hub?
errr yea, the axle isnt sticking far enough through the wheel to get the spacer and nut on.marcus57 wrote:Yeah , it was quite hard to get it in place and take a photo, can you see an issue?
Try and find a centre point on the subframe and see if it lines up with the centre of the wheel. Isnt there something called offset? or is that just for car wheels? Im sure if the offset is wrong then the wheel wont sit centre on the bike.
Dont quote me on this tho i just vaugly remember something along them lines
marcus57
No that does make sence , like I say my dad is really good with this sort of thing so I will let him have a look at it , will be gutted if they don't fitDrunkn Munky wrote:errr yea, the axle isnt sticking far enough through the wheel to get the spacer and nut on.marcus57 wrote:Yeah , it was quite hard to get it in place and take a photo, can you see an issue?
marcus, pop to a local bike garage and ask them to fit a knackered tyre so you can try it for size?
marcus57
thats another thing on my to do list, its going to be bloody close , if i do have to sell them at least i will be able to afford to have it paintedporndoguk wrote:marcus, pop to a local bike garage and ask them to fit a knackered tyre so you can try it for size?
could always do a swing arm conversion!marcus57 wrote:thats another thing on my to do list, its going to be bloody close , if i do have to sell them at least i will be able to afford to have it paintedporndoguk wrote:marcus, pop to a local bike garage and ask them to fit a knackered tyre so you can try it for size?
marcus57
porndoguk wrote:could always do a swing arm conversion!marcus57 wrote:thats another thing on my to do list, its going to be bloody close , if i do have to sell them at least i will be able to afford to have it paintedporndoguk wrote:marcus, pop to a local bike garage and ask them to fit a knackered tyre so you can try it for size?
