Charging system readings with uprated parts
Bearing in mind i have the GSXR genni conversion and R6 reg on my bike would a reading of 13.5V idle and 16V @5k rpm be normal? Haynes manual and the guide on the home pages states a max of 15.5V and normal reading of around 14.5. Should i be concerned?
Re: Charging system readings with uprated parts
16 @5v is too much dude.
if you check the AC guides - you see 50v AC @ 5k revs for a std genny.. mine was hoofing out 80+
the battery doesn't want to see anything too close to 15V whatever is charging it..so reg rec seems to have gone french on you..
Would it be a case of the red and green wire being the wrong way round? It meant to be opposite to the NC30 setup but i only had some dodgy pics to go on.
if they were wrong your main fuse would pop
Right defo a dodgy reg then? Thats a fucker, i sure when i brought it new and sealed.
I have a working one man - I'll send it you so you can test it.
hit me your address
- royster81
I love the greybike brotherhood
There usually 14.1 - 14.4v no matter where the revs are.
Test your genny before you fit the Reg Rec from Mark just incase.
16v will be over-charging the battery so best to get it sorted :)
Will test the alternator first thing tomorrow, if thats fooked then i wont be a happy bunny
you got a multimeter tony?Drunkn Munky wrote:Will test the alternator first thing tomorrow, if thats fooked then i wont be a happy bunny
ill post that tester out to you if you need it straight away,
im gonna take the 30out for a ride sat and ill hold on to the tool just wanna make sure everything rides right.
so if i have to adjust any thing when i return. i can do the swingarm etc.
