NC30 nit starting arrrrrrrrrrgggggghhhhhhhhh
Hello, My NC30 has been sat up over winter and as i brought me a GSXR600 i decided to sell up
went out to the bike last weekend and it wouldnt start so after a little bit of playing she fired into life
so i left it in the garage and this morning i had someone come and view it. went out to it and it wouldnt start again (I did leave the fuel tap on during the week, dont know if this had anything to do with it) it fired a couple of times and wouldnt run with or without choke revs or no revs. any help would be most welcome as he wants to come and view the bike again when i have it running. I think i may have cooked the plugs but before gettin new one and rippin my knuckles apart just wondered if u guys had any ideas.
Re: NC30 nit starting arrrrrrrrrrgggggghhhhhhhhh
Spray a bit of carb cleaner into the airbox (under the headstock will do) and see if that helps it catch.
When it does catch, then let it get properly hot. take it for a ride if you can.
Probably plugs...but you might be able to whip the rear ones out, clean them and dry them...then see how you go
i had the rear ones out earlier and cleaned and dried them with no luck, i think i will have to go and grab some new ones in the morning
some flammable aerosol dude..try it.
Pretty sure Royster has been guilty of using Lynx..lol
spray it where in the front of the air box?
- Martin
He's such a Dandy. The exhaust fumes smell a lot nicer thoughCMSMJ1 wrote:some flammable aerosol dude..try it.
Too spensiff!!!
- geebus
- Bike owned: 1990 VFR400 NC30 + SV650s
nice way to attract the girls i suppose.
You get old bikers and bold bikers, but no old bold bikers
Both my 400/4 and my Triarm sulk if not started for ages... the fuel runs back thro the carbs, I usually find a quick whiff of easystart starts it straight up...
well had it started yesterday and today after fittin a new set of plugs, then went to start it when the guy come to look at it and it wouldnt start, fireed ran for a couple of secs then cut out and wouldnt start not even bumpin it. any one else got any idea. gettin close to sellin it as a non-runner
Sounds like you are flooding it. have you tried an aerosol to get it going??
How long was it sat without running, might need to put the effort in and sort the carbs. otherwise, Geoff will come and get it and take it to bits
